Master agent is busy
Jun 9th, 2010
I tried setting up a backup for my CCM 8.5.  But now when I try to go  back into the Disaster Recovery System and click on the back up I set  up...it just keeps showing:
"Status: Unable to process request,  master agent is busy"
How can I clear this and try to set this up  again?
Overall Rating: 5 (1 ratings)
Aaron Harrison Thu, 06/10/2010 - 01:25
  • Community Spotlight Award,
    Member's Choice, May 2015
CCM 8.5? You are on the leading edge of technology...
Go into 'Control Center - Network Services'. Listed there are the DRF Master and DRF Local services that make up this service. Restart the DRF Master, and leave it a few minutes to settle then try again.
Network Services is in the Serviceability pages (https://ccm-ip/ccmservice)
Aaron
Please rate helpful posts..
samayann Thu, 06/10/2010 - 01:37
     Thank you for replying, But ithat solution is not working. Have been restarting the DRF local and Master Sevices since morning. Any other way of resolving it ?
Sanjana
ramondelacruz Sat, 09/15/2012 - 06:38
Go to CUC Serviceabilty > Tools > Cluster Management > Port Manager, for Publisher click on Stop Taking Calls.
This should now allow you to restore a backup.
erinedison Tue, 05/19/2015 - 14:50
HI Samayann,
i had this same issue,resolved by
Restart the service from the Command Line Interface on both publisher and subscriber, use these commands
  • admin:utils service restart Cisco DRF Master
  • admin:utils service restart Cisco DRF Local
Erin
WASEEMULHAQ Wed, 12/02/2015 - 23:28
From PUB Control Center - Network Services'. instead of restarting do STOP  DRF Master only . waite for 10 min than start DRF Master service again .
