Microsoft SCCM 2007 OSD Problem with Cisco 6509 DHCP
Jun 7th, 2010
I have Microsoft SCCM 2007 Server, which is under VLAN15, i am using Catalyst 6509E as my DHCP with several VLANs. i have tested by creating a test dhcp pool range within same VLAN where my SCCM 2007 server resides, OSD (operating system deployment) deployment is successful without any errors. Across the VLANs i get errors while OSD deployment. under test DHCP pool i have added option 66, 67 plus i have also tried ip helper address under vlan interface but didnt help. Find my configuration for Servers VLAN and Client VLAN below.
By Client computer BIOS option are to boot from NIC.
Servers VLAN
interface Vlan15
description SERVERS
ip address
Client VLAN
interface Vlan30
ip address
ip helper-address
Note: is my SCCM 2007 Server, i have also tried as ip helper didnt help as well
Client DHCP Excluded Range
ip dhcp excluded-address
Client DHCP Pool
ip dhcp pool sccm
   bootfile pxeboot
   option 66 ip
   option 150 ip
   option 43 ip
   option 67 ip
Note: is SCCM 2007 Server
If i remove ip helper from interface VLAN of client, Client  takes IP address across VLAN but dont start OS deployment. i recieve below error.
PXE-E32: TFTP Open Timeout
If i provide ip helper address (SCCM 2007 Server ip address under client VLAN i recieve below error.
PXE-T04: Access Violation
PXE-E36: Error Recieved from TFTP Server
PXE-M0F: Exiting Intel Boot Agent
Quick response will be appreciated.
