MCS Serial Number
Jun 10th, 2010
Hi there,
I have a MCS-7825-I1-CC1 with UCCX 7.x installed (Windows 2003).. I could not find the serial number outside chassis...
Is there any way to check the serial number via Windows ?
Thanks.
Andrei.
Overall Rating: 4 (1 ratings)
Aaron Harrison Thu, 06/10/2010 - 06:12
The other option is to access the 'HP System Management Homepage'. This is a web page served up by a HP service, it allows you to monitor all sorts of stuff about the server and the iLO card. I'm certain that can display the serial number...
Sometimes you find it's disabled - go into the service control panel, enable and start it. You log in by going to http://server-ip:2381/ and logging in using the local administrator and password.
There may also be a shortcut to it under Start/Programs.
Aaron
Please rate helpful posts...
