HW Config : 2951 & voice PRI card
Jun 10th, 2010
Hello experts,
We have a C2951 router and we want to connect a PRI line on it for voice calls. I am confused as to which specific card/module should buy for this job. Any ideas?
Thank you in advance for your answer
Nikos
Overall Rating: 4.5 (2 ratings)
William Bell Thu, 06/10/2010 - 04:35
  • Purple, 4500 points or more
Nikos,
There are several options available to you.  Take a look at this link for the options:
http://www.cisco.com/en/US/products/ps10536/products_relevant_interfaces_and_modules.html#voicemod
This module is a good candidate based on your high level description:
VWIC2-1MFT-T1/E1
1-port T1/E1 Voice / WAN w/ Drop &  Inser
In addition to the T1 module, you will need DSPs. DSPs are used by the router for voice termination, media mixing, transcoding, etc.   DSPs for the ISR (and ISR G2) are provide on carrier cards called PVDMs.   Your router support the PVDM3  (generation 3).  Review this sheet to help you pick the PVDM that is right for you:
http://www.cisco.com/en/US/partner/prod/collateral/modules/ps3115/data_sheet_c78-553971_ps10537_Products_Data_Sheet.html
HTH.
Bill
Please remember to rate helpful posts.
Related Content
