(IPv6) DNS entry is not published by the DHCP-Server
Jun 10th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Normale Tabelle"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
We are trying to setup an IPv6 DHCP-Server on a Cisco 878 (c870-advipservicesk9-mz.124-15.T13.bin). The clients (Windows XP) are getting no DNS entry from the DHCP-Server. We have to add them manually on every client (netsh), which is not very cool. Can you help me find the problem?
Here is a part of the code:
ip name-server 2001:XXX:XXXX:6::53
ipv6 unicast-routing
no ipv6 source-route
ipv6 cef
ipv6 dhcp pool dhcppool
prefix-delegation 2001:XXX:668::/48 0007
dns-server 2001:XXX:XXXX:6::53
dns-server 2001:XXX:XXXX:6:0:153:235:53
domain-name blablabla.com
interface Loopback0
no ip address
ipv6 address 2001:XXX:668:111::1/128
ipv6 enable
interface Vlan20
ip address 10.X.X.1
ipv6 address 2001:XXX:668:1::1/64
ipv6 enable
ipv6 dhcp server dhcppool
ipv6 local pool dhcppool 2001:XXX:668::/48 50
ilgorro2010 Tue, 06/15/2010 - 04:35
I´m now booting the latest (stable) version  (c870-advipservicesk9-mz.124-22.T5.bin) but the problem is still the  same.
Related Content
