A question about ASA 8.3 global ACLs against interface ACLs
Answered Question
Jun 10th, 2010
Hello Cisco Experts,
I have a question about the Global ACLs feature introduced in ASA 8.3.
Which ACLs are match first, Global ACLs or the regular interface-base ACLs?
As I understood, if both Blobal and interface-base ACLs exist in the policy, the firewall will try to match (incoming/outgoing) traffic against the interface-base ACLs and if no match is found then the firewall tries  to match the traffic against the Blobal ACLs.
is that correct?
thank you
Correct Answer by edadios about 6 years 9 months ago
It matches interface acl first before global.
Here is the documentation for your reference :
http://www.cisco.com/en/US/docs/security/asa/asa83/configuration/guide/access_rules.html#wp1083595
You can configure global access rules in  conjunction with interface access rules, in which case, the specific  interface access rules are always processed before the general global  access rules.
Overall Rating: 5 (1 ratings)
Correct Answer
edadios Thu, 06/10/2010 - 06:03
  • Silver, 250 points or more
