PAT Question
Answered Question
Jun 10th, 2010
Can I PAT port groups to two internal IP's?  For instance, I want my single external ip to be PAT'ed to 10.10.0.15 using tcp range 50000-50010 and PAT'ed to 10.10.0.16 on udp range 6004-6999.  I have not been able to find a solution other than creating PAT statements for each individual port which will take forever and clutter the config.
Thanks in advance.
Correct Answer by Federico Coto F... about 6 years 7 months ago
You can PAT a single external IP to multiple internal IPs and it is sometimes called port redirection.
But as you said, this option is to redirect individual ports (not a range).
You''ll better have different IPs mapped to the internal devices if you want to accomplish this.
Federico.
Overall Rating: 5 (1 ratings)
Correct Answer
Federico Coto F... Thu, 06/10/2010 - 07:09
Federico.
