(IPv6) DHCP-Server is not reachable (via connection)
Jun 10th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Normale Tabelle"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
We are trying to setup an IPv6 DHCP-Server on a Cisco 878 (c870-advipservicesk9-mz.124-15.T13.bin). There is another problem with the availability of the router. When you boot the router, he is broadcasting the IP-addresses but after about 30 minutes he going “stealth”. He doesn´t broadcast any more and he is not reachable via ping. Only a reboot can “solve” the misery/situation.
Do you have any guess/clue?
Here is a part of the code:
ip name-server 2001:XXX:XXXX:6::53
ipv6 unicast-routing
no ipv6 source-route
ipv6 cef
ipv6 dhcp pool dhcppool
prefix-delegation 2001:XXX:668::/48 0007
dns-server 2001:XXX:XXXX:6::53
dns-server 2001:XXX:XXXX:6:0:153:235:53
domain-name blablabla.com
interface Loopback0
no ip address
ipv6 address 2001:XXX:668:111::1/128
ipv6 enable
interface Vlan20
ip address 10.X.X.1
ipv6 address 2001:XXX:668:1::1/64
ipv6 enable
ipv6 dhcp server dhcppool
ipv6 local pool dhcppool 2001:XXX:668::/48 50
Giuseppe Larosa Thu, 06/10/2010 - 09:38
Hello Hannes,
this looks like a SW bug so I would suggest to download and install a newer image for your router and to test with it
I couldn't find a match using IPv6 DHCP in bug toolkit
Hope to help
ilgorro2010 Mon, 06/14/2010 - 23:35
Fine Thnx. I will try a newer one, if i find one that maches my needs.
ilgorro2010 Tue, 06/15/2010 - 04:05
I´m now booting the latest (stable) version (c870-advipservicesk9-mz.124-22.T5.bin) but the problem is still the same.
For testing reasons i disabled the whole ipv6 code to see how it is running only with ipv4, and under ipv4 everything works fine.
Hmmm. Any other guesses?
ilgorro2010 Wed, 06/16/2010 - 05:17
Status update: When I´m pinging the DNS-server and the router from my pc, the router won´t ever crash. But when i start a download from an ipv6 ftp-server, the router is not reacheable after a few minutes.  It looks like that he can only handle icmpv6 messages but no ftp transfer. ;(
