CUPC Dialing Shared Contact Group
Jun 10th, 2010
We are seeing an issue with the outlook CUPC client that is preventing users from dialing their contacts.
If they go into their personel contact list, they can choose a contact, then use the CUPC drop down tool bar to select which number to dial (Business, Cell, Home, etc).    They pick the number, it then dials their phone for them.
If they have access to someone else's contact list, they loose this ability.     The CUPC toolbar does not show the Business, Cell, Home etc options to allow them do dial their phone.   This is also the case for Public folder contacts.
Is there a way to fix this so they can use their CUPC plugin to dial these numbers?
mhurley131 Thu, 06/10/2010 - 07:48
Ouch, thats pretty stupid.    Has there been any confirmation that 8 will fix it?
What have people been doing in the mean time?   Is Click-to-Call a better option?
say8746 Wed, 07/14/2010 - 12:37
Can you please clarifywhat's meant by "local contacts"?
htluo Wed, 07/14/2010 - 12:43
"local contacts" means the contacts you created manually from your Outlook.  Not the contacts that downloaded from Exchange server (a.k.a. GAL - Global Address List).
say8746 Wed, 07/14/2010 - 13:32
The work around would be to add/save the Global address locally which isn't really a big deal unless I'm missing the point? thanks....
htluo Wed, 07/14/2010 - 13:34
I don't know how to add the Global address locally.  Would you mind sharing?
say8746 Wed, 07/14/2010 - 13:41
In the address book, when I right click the contact name I get three options one of which is "Add to contacts". Select it and use one of the save options to save it (save and close, save and new or just save ...)
htluo Wed, 07/14/2010 - 13:43
Oh... I see.  Ya, of course you can do that.  But how about the other 11,000 users in GAL?  Is there any easy way to add 11,000 users from GAL to local contacts?
mhurley131 Wed, 07/14/2010 - 13:41
Copying shared contacts to each users local contacts completely defeats the purpose of a public contacts folder. The purpose of a shared contact list is to have a single place to update contacts that are used by multiple users.    This way it is extremely easy to update, add, remove the contacts.   If each users had a local copy of these numbers, it would be a nightmare to makes changes or additions.
