QRT CCM v7.1.3
Jun 10th, 2010
I have QRT setup and working but when
the softkey is used not all the options are visible
on the phone.
For example these are missing when connected:
Low volume, The remote end experiences low volume, I can't hear the remote end, The remote end can't hear me.
Can anybody explain why this is?
Regards, Martyn
Jonathan Schulenberg Thu, 06/10/2010 - 10:59
  • Cisco Designated VIP,
    2017 IP Telephony
These are controlled by a service parameter on the Cisco Extended Functions service.
Display Extended QRT Menu Choices: Required FieldThis parameter determines whether additional menu choices are  presented to the user after the QRT softkey is pressed during an active  call. The extended menu provides a list of choices that the user can  choose to explain the quality problem that is occurring, such as 'I hear  echo.' Valid values specify True (display extended menu choices and  after the user has made a choice, show the acknowledgment screen) or  False (just show the acknowledgment screen; do not display extended menu  choices).
This is a required field.
Default:                  False
Martyn Sharpe Thu, 06/10/2010 - 15:02
Some of the menu options are available but not all of them. 'I hear echo, Remote end hears echo, Choppy audio, Robotic sound, and Long delay' are available but not the others mentioned.
