Easy VPN Client and multiple subnets
Jun 10th, 2010
Can the Easy VPN  Client send more than one subnet dynamically across the tunnel ? We're seeing the dynamic ACL that get's built, only allowing the directly connect subnet on the inside interface. We have multiple subnets on the inside which the ASA5505 knows how to get to. The vpnclient mode is in network-extension-mode  and it's important for us to have bydirectional communication after the tunnel is established from the client side, client mode is not an option.
ASA version - 7.2(4)
Federico Coto F... Thu, 06/10/2010 - 12:04
  • Green, 3000 points or more
Originally Eazy VPN allows only the directly connected network on the client side to communicate through the tunnel.
Recently there has been improvements to allow more than one network (but only on IOS).
If you have an ASA as the hardware client, then there's still no option as fas as I'm aware.
Federico.
