Disable led on 1131AG while associated with an WLC
2044418Puts
On autonomous AP's one can disable the bright status LED using the "led ....." command. But how can I disable the LED on a LAP-1131AG? The AP hangs in a bedroom so the light is quite annoying.
Thanks!
2044418Puts
OOPS.... found it already..
config ap led-state disable all
Anyone know if this can be done through the web GUI, or just on the command-line?
Depends on the firmware of the WLC.
7.0.X doesn't support this on GUI but 7.4.100.X does.
In 7.0.X, you can enable/disable LED globally but 7.4.100.X have an option to do so individually.
NOTE:  Not sure which firmware starts the support but all my WiSM-2 are running 7.4.100.X.
