Service Policy
Jun 10th, 2010
I noticed that on one of our 3750 switches we have both the mls qos trust cos and service-policy input AutoQoS-Police-CiscoPhone command on all the interfaces.  I believe the macro apply cisco-phone may have put both of these commands on each interface.  We do not use any policy maps on interfaces.  Should the service-policy command be removed from the interfaces?  Will having both the mls qos trust cos and service-policy commands on an interface cause any problems?
Overall Rating: 5 (3 ratings)
Mohamed Sobair Thu, 06/10/2010 - 14:17
Without QoS  policy applied Inbound and outbound, these commands would have no affect.
Mohamed
Ganesh Hariharan Thu, 06/10/2010 - 22:32
To attach a policy map to an interface, use the service-policy input command.
service-policy input policy-map name
If you entered the auto qos voip cisco-phone command, the switch automatically creates class maps and policy maps
Switch(config-if)# service-policy input AutoQoS-Police-CiscoPhone
After creating the class maps and policy maps, the switch automatically applies the policy map named AutoQoS-Police-CiscoPhone to an ingress interface on which auto-QoS with the Cisco Phone feature is enabled.
mls qos trust cos command is Interface configuration command for trusting when a Cisco Phone is learned via CDP on the respective interface; works in conjunction with the mls qos trust dscp and mls qos trust cos commands
Hope to Help !!
Ganesh.H
Remembe to rate the helpful post
Hitesh Vinzoda Thu, 06/10/2010 - 23:07
Hi,,
As you said if you organisation doesnt require service-policy, you can remove it
No, as mls qost trust cos is only trusting the COS received on the interface and, Service policy is applying what is configured under the policy map
Hitesh Vinzoda
Pls rate useful posts.
