CAM licensing issue
Answered Question
Jun 10th, 2010
Hello Guys, I ´ve tried to add CAS server into a CAM but I got an error that says
Failed to add server: Maximum limit for Clean Access  Servers supported has been reached
but the CAM has a super manager License present along with a Manager Failover License. This license was sent to me by Cisco
Product Name                   : NACMGR-40FB-K9
Product Description            : NAC Appliance 3390 Manager Failover Bundle -max 40 Servers
what could be wrong ??  Thanks for the help..
Correct Answer by Faisal Sehbai about 6 years 8 months ago
To expand on what Laxman said, even though you have a 3390 that CAN manage 40 CASs, for each CAS you want to add to the CAM, you will first need to add a CAS license to the CAM. Whenever you go to the licensing page to generate a CAS license, ALWAYS use the CAM's eth0 address, since licensing is all based on the CAM. Once you get a license for the CAS using the PAK that comes with each CAS, add it to CAM, and then you should be able to add the CAS to the CAM.
HTH,
Faisal
Correct Answer by blaxucisco about 6 years 8 months ago
Hi muozmellado,
To add the CAS into the CAM you have to have CAS license. for CAS license you have to request with Product Authorization Key (PAK) which is comes with CAS. During this process you have to provide both CAM (primary and secondary) mac address. once you get the CAS license install this license into cam and try do add CAS into the CAM.
Thank you
Overall Rating: 5 (2 ratings)
j.muozmellado Thu, 06/10/2010 - 14:40
I don´t have any CAS added to this CAM, that is the wired thing...do I need to enable something else into the CAM to make it work out ??? I thought that it was enought with the license file....Thanks
Correct Answer
blaxucisco Thu, 06/10/2010 - 18:54
Hi muozmellado,
Thank you
j.muozmellado Tue, 06/22/2010 - 07:32
Hi Laxman:
Thanks for your help...I did what you mentioned before, and it worked out.
Correct Answer
Faisal Sehbai Thu, 06/10/2010 - 19:50
HTH,
Faisal
