VOIP outgoing call issue
Jun 10th, 2010
Could I know how to fix it the following issue ? Users said when they press the digit slowly then the calls are successful. When they press faster, they hear busy tone.
Users are having problem to make leased line calls. The pattern is before they complete the key-press, they hear the busy tone.  To call a extension in HK, e.g. 484, I need to press 382484, where 3 is the access code to the tie-line, 82 to RSHK, and 484 is the extension. Now after I press 382, there is busy tone already. We keep trying for few more times, we can then get thru.
Thanks a lot
Leung che man
David Hailey Thu, 06/10/2010 - 21:32
  • Purple, 4500 points or more
You need to check for overlap in your dial plan.  Then we can go from there.
Hailey
Please rate helpful posts!
cm6043 Thu, 06/10/2010 - 22:41
Hi Hailey,
The dialplan is not overlapped with each other. Is this the problem about the timing of dial digit ?
RSHZ#sh dial-peer voice summary
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT
11     pots  up   up             86                 0                      up   0/0/0:1
101    voip  up   up             82[1-8]T           0  syst ipv4:1.1.1.1
102    voip  up   up             829T               0  syst ipv4:1.1.1.1
111    voip  up   up             84[1-8]....        0  syst ipv4:2.2.2.2
112    voip  up   up             8491817T           0  syst ipv4:2.2.2.2
121    voip  up   up             83[1-8]T           0  syst ipv4:57.3.3.3.3
122    voip  up   up             839T               0  syst ipv4:57.3.3.3.3
131    voip  up   up             88[1-8]T           0  syst ipv4:57.4.4.4.4
132    voip  up   up             889T               0  syst ipv4:57.4.4.4.4
RSHZ#
Leung Che Man
paolo bevilacqua Thu, 06/10/2010 - 22:46
  • Hall of Fame,
    Founding Member
There is no match for 382 above ? Also see if you can register a phone into thta site and try yourself, sometime users report are incorrect.
cm6043 Thu, 06/10/2010 - 23:57
The prefix 3 is deleted before accessing the voice gateway so only 82xxx will be sent.
Thanks Leung Che Man
