"Re-export" routes
Jun 11th, 2010
Hi all,
I have a senario where I import routes fra VRF-A (RT 65002:4021) into VRF-B (RT 65001:1200).
I now would like to import the same routes (the ones imported from VRF-A) from VRF-B (RT 65001:1200) to VRF-C (RT 65002:1000).
Can this be done? If yes, how?
Arnfinn
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Fri, 06/11/2010 - 08:59
  • Hall of Fame,
    Founding Member
Hello ArnStran,
the correct way to do this is to export from source VRF VRF-A with both RT set
for example using a route-map as export-map
route-map myexport permit 10
match ....
set extcommunity RT 65001:1200 65002:1000 additive
ip vrf VRF-A
export-map myexport
you cannot re-export from VRFB to VRFC to avoid possible routing loops
Hope to help
Giuseppe
