File Format for export from Ciscoworks to ACS
Jun 11th, 2010
I want to export devices from Ciscoworks lms 3.2 to ACS 4.1 with the cli-tool
dcrcli expAcs
But, what is the file format I have to use
lsattr gives me just the complete list of all cs-attributes
thanks, William
Joel Monge Fri, 06/11/2010 - 07:36
If you do not specify the file name,
–In Non-ACS mode all the devices from DCR will be exported to the specified server.
–In ACS mode, only the devices that are not configured in ACS will be exported from DCR to the specified server.
The file format is the same as when you export the devices from DCR.  If you perform an export to a CSV for example, the tool will use that last file unless another file is specified.
Related Content
