ip policy route-map on 3750
Jun 11th, 2010
I try to enter the command "ip policy route-map"  on 3750's interface. But the command doesn't appear.
Why? Whereas I see several times that this command is possible on this switch.
What I have to do to enter this command?
Thanks!
Overall Rating: 5 (2 ratings)
Jon Marshall Fri, 06/11/2010 - 02:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Sebastien
To run PBR on the 3750 you need -
1) to be using the IP services image and not the IP Base image
2) you need to run the routing sdm template ie.
3750# sh sdm prefer
will show you the current template
3750(config)# sdm prefer routing
will enable the routing template.
Note that a change in the sdm template requires a reload of the switch.
Jon
sebastien.fr Fri, 06/11/2010 - 02:29
How to activate the "Ip services image" instead of "Ip base image"?
Because I just have activated PBM like you wrote it and the command "ip policy route-map" still doesn't appear.
I use the IOS 12.2(35) version.
sapetrola Tue, 06/12/2012 - 05:31
Excellent! It worked this way for me. Thanks a lot.
FABIO BETTINI Sun, 10/06/2013 - 01:39
Hi John,
I have the same problem Sebastian has, and I have a cisco catalyst WS-C3750G-24PS stack with four switches.
I'm using C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE8.
I also inserted the command you described about to prever SDM routing profile exactely as you described but I'm still unable to insert the command ip policy router-map statement on the virtual inteface.
What I'm doing wrong ?
Thank's a lot for yoour further suggestions
Fabio
