1242AG Help
Answered Question
Jun 11th, 2010
I am trying to configure a
1242AG with 2 Vlans, Guest and Admin - there is an example paper by Cisco showing just this scenario but it doesn appear to work-  I was convinced the configuration is correct but the users PC cannot see either SSIDs - Guest is set to WEP and Admin is set to WPA2 TKIP - is there any way I can show that the 1242 is transmitting ?
many thanks
Overall Rating: 5 (1 ratings)
KeithN123 Fri, 06/11/2010 - 09:18
Andrew -
apologies for the rating - I tried to give it maximum
but for some reason only got 4 star !!
Many thanks for your help
regards
Keith
