isdn test call - call rejecte
Wassim Aouadi
Level 4
Level 4
Hi networkers,
I have an ISDN line as a backup on our router. When I wanted to test it, I saw "call rejected" message:
TNRTEXCS02A1#debug isdn q931
debug isdn q931 is              ON.
TNRTEXCS02A1#
TNRTEXCS02A1#
TNRTEXCS02A1#isdn test call inter ser0/2/0:15 71979919
TNRTEXCS02A1#
*Jun 11 11:04:26.757 UTC: ISDN Se0/2/0:15 Q931: Sending SETUP  callref = 0x012D callID = 0x80AF switch = primary-net5 interface = User
*Jun 11 11:04:26.757 UTC: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8  callref = 0x012D
        Bearer Capability i = 0x8890
                Standard = CCITT
                Transfer Capability = Unrestricted Digital
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Called Party Number i = 0x81, '71979919'
                Plan:ISDN, Type:Unknown
*Jun 11 11:04:26.793 UTC: ISDN Se0/2/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x812D
*Jun 11 11:04:26.889 UTC: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8  callref = 0x01FD
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98382
                Exclusive, Channel 2
        Calling Party Number i = 0x008
TNRTEXCS02A1#3, '71979919'
                Plan:Unknown, Type:Unknown
*Jun 11 11:04:26.893 UTC: ISDN Se0/2/0:15 Q931: Received SETUP  callref = 0x81FD callID = 0x01FE switch = primary-net5 interface = User
*Jun 11 11:04:26.893 UTC: ISDN Se0/2/0:1: Incoming call rejected, unbindable
*Jun 11 11:04:26.893 UTC: ISDN Se0/2/0:15 **ERROR**: call_incoming: DIALER ERROR 0x1: b channel 1 call id 0x1FE
*Jun 11 11:04:26.893 UTC: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x81FD
        Cause i = 0x8095 - Call rejected
*Jun 11 11:04:26.945 UTC: ISDN Se0/2/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x812D
*Jun 11 11:04:26.945 UTC: ISDN Se0/2/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x012D
*Jun 11 11:04:26.961 UTC: ISDN Se0/2/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x812D
TNRTEXCS02A1#
Any help?
5 Replies 5
paolo bevilacqua
Send "show diag" and "show conf".
Here they are
Alls seems good, you may need to bring this to the TAC.
Could it be because of the IOS? I have a 3925 chassis .
I attached the "show version" output if it helps
I found it. I removed the 'dialer remote-name" and it worked. I think it was an authentication issue because both PPP chap hostname and dialer remote-name were set under the dialer interface
