Multicast problem
Jun 11th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-fareast-language:EN-US;}
Hi all,
I have begin implementing multicast in an enterprise environment with catalyst 6500 and 4500 in a L3 routed network as in the picture:
The access network with 4500 switches are extend the LAN at L2 with 3560,2960,2940 switches. I use PIM and IGMP for distributing multicast traffic on the network and  have a WMS server as the multicast source connected in the core. Clients/receivers connected to 4500 and 3560 are working fine, but I  have some problems with 2940 and 2960 switches.
The problem is that the movie/stream is “jagged” and it stops buffering for periods. The higher rate, the worse.  If I change the 2940/2960 with an 3560 its works fine.  The switches are L2 and are running igmp snooping.
Any suggestions or experiences with multicast on these switches?
