the vpn client driver has encountered an error xp
Jun 11th, 2010
Hi All,
    Can any one please help me on fixing this error for Cisco anyconnect-win-2.1.0150 on XP I need to login to VPN. but i am getting this error. Please check and help me ....
Nagesh
JORGE RODRIGUEZ Wed, 06/16/2010 - 12:25
  • Green, 3000 points or more
Hi Nagesh, I have look this for you, I quoted  from link bellow.  try that see if  resolves the issue.  or try installing the version  2.3 which was fixed .  http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00809b4754.shtml#rty
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00809b4754.shtml#erm
This issue is due to Cisco bug ID CSCsm54689  . In order to resolve this issue, make sure that Routing and Remote Access Service is disabled before you start AnyConnect. If this does not resolve the issue, complete these steps:
  1. Open a command prompt as an Administrator on the PC (elevated prompt on Vista).
  2. Run net stop CryptSvc.
  3. Run esentutl /p %systemroot%\System32\catroot2\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\catdb.
  4. When prompted, choose OK to attempt the repair.
  5. Exit the command prompt.
  6. Reboot.
CSCsm54689 Bug Details
Anyconnect, non-informative error with routing and remote access service
Symptom:
When RRAS enabled on the windows PC anyconnect will fail will error message "The VPN client driver has encountered an error." Although anyconnect will not function with Routing and remote access service on, the error is misleading and should be more informative to tell the customer what the actual problem encountered was.
Conditions:
Routing and Remote Access Service enabled in windows
Workaround:
make sure Routing and Remote Access Service is disabled before starting anyconnect.
Further Problem Description:
none
ladeq4specproj Thu, 06/17/2010 - 07:30
I've found that this has worked in about half the cases, but lately I'm seeing this message and now this fix is not working at all.  Could there be another cause for this error message that is not being addresed?
