ACE module and NEXUS 7000
Jun 11th, 2010
Is it possible to connect an ACE Module to 2 Nexus 7000 switches with vPC?
This would allow to have 2 active links and make a more redundant design avoiding to use an orphan port to connect to the ACE module/6500.
Any feedback apreciated.
Giulio.
Sean Merrow Fri, 06/11/2010 - 07:26
  • Silver, 250 points or more
Hello Giulio,
I'm not sure I'm understanding your question, but let me give it a shot.
The ACE module won't actually "connect" to a Nexxus switch.  From the ACE's perspective, as well as the Catalyst switch in which it resides, the ACE is connected via a Tengig port across the backplane.  In your Sup's config, you allocate VLANs to vlan-groups, and apply the vlan-groups to the ACE.  From your ACE's view, it doesn't know what the view is beyond this Tengig port (we only call it a Tengig port because there is no 16Gig port name).
So while I'm not sure if this was tested in a lab, I can't think of any reason why you couldn't have a vPC between the Catalyst 6500 and your Nexxus 7000.
Hope this helps,
Sean
