ipv6 addresses on router interfaces
Jun 11th, 2010
Hi all
when I put a site local ipv6 address on a router, will there also be a link local address automatically created prior to this? bascially when I enable th eipv6 unicast routing command?
cheers
Carl
Reza Sharifi Fri, 06/11/2010 - 09:19
  • Cisco Designated VIP,
    2017 LAN
Not when you enable IPv6 routing.  It assigns link local address automatically after you put the ipv6 on the interface with EUI
ipv6 address FEC0:1:2::/64 eui-64
Reza
Chetan Kumar Ress Fri, 06/11/2010 - 09:20
  • Silver, 250 points or more
Hi Carl
When you enable an IPv6 on router then by defaul the Link Local address is addign to router interface & That address actually use you MAC address to make an unique address , The process is know an EUI-64& it start with "FE80::0"
Please refer the below link.
http://www.cisco.com/web/about/ac123/ac147/archived_issues/ipj_7-2/ipv6_autoconfig.html
Chetan Kumar
