delete files from flash
Answered Question
Jun 11th, 2010
hello
I' have a 2851 on IOS 12.4(9)T
there are some files that show up on the flash with deleted between brackets
BCR-2851-CUCME#
ABCR-2851-CUCME#sh vlash               flash
CompactFlash directory:
File  Length   Name/status
  1   31050152  c2800nm-ipvoicek9-mz.124-9.T.bin
  2   4522     admin_user.html
  3   653335   admin_user.js
  4   8160     Analog1.raw [deleted]
  5   8160     Analog2.raw [deleted]
  6   5040     AreYouThereF.raw [deleted]
  7   5280     AreYouThere.raw [deleted]
  8   8160     Bass.raw [deleted]
  9   12240    CallBack.raw [deleted]
10   16040    Chime.raw [deleted]
12   8160     Classic1.raw [deleted]
13   16080    Classic2.raw [deleted]
14   10800    ClockShop.raw [deleted]
15   896      CME_GUI_README.TXT
16   1706643  cmterm_7936.3-3-5-0.bin
17   1998336  cnu41.2-7-6-26.sbn [deleted]
18   1960127  CVM41.2-0-2-26.sbn [deleted]
20   495      DistinctiveRingList.xml [deleted]
21   16344    dom.js
23   9600     Drums1.raw [deleted]
24   13440    Drums2.raw [deleted]
25   6146     ephone_admin.html
26   15840    FilmScore.raw [deleted]
27   16080    HarpSynth.raw [deleted]
28   8160     Jamaica.raw [deleted]
29   707135   Jar41.2-9-2-26.sbn [deleted]
30   16080    KotoEffect.raw [deleted]
32   12720    MusicBox.raw [deleted]
33   496521   music-on-hold.au
34   3724     normal_user.html
35   79912    normal_user.js
36   8160     Piano1.raw [deleted]
37   15360    Piano2.raw [deleted]
39   9360     Pop.raw [deleted]
40   7200     Pulse1.raw [deleted]
41   4000     Ring1.raw [deleted]
42   4000     Ring2.raw [deleted]
43   4000     Ring3.raw [deleted]
44   4000     Ring4.raw [deleted]
45   4000     Ring5.raw [deleted]
46   4000     Ring6.raw [deleted]
47   4000     Ring7.raw [deleted]
48   495      RingList.xml [deleted]
49   10800    Sax1.raw [deleted]
50   14160    Sax2.raw [deleted]
53   2393     telephony_service.html
54   591      TERM41.7-0-3-0S.loads [deleted]
55   591      term41.default.loads [deleted]
56   591      term61.default.loads [deleted]
how do i get rid of them properly ?
thanks
Correct Answer by Giuseppe Larosa about 6 years 9 months ago
Hello Cristobal,
it looks like you need to use
squeeze flash:
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Fri, 06/11/2010 - 09:08
  • Hall of Fame,
    Founding Member
Hello Cristobal,
squeeze flash:
Hope to help
Giuseppe
