Allowing RDP to pass through ZBF
Jun 11th, 2010
I am setting up ZBF for a remote office that has a single server that needs to be reachable via the Internet.  So that I can get into the server remotely since it is on a standalone connection from our MPLS network, I have entered the following lines into the router config -
ip access-list extended ACL_RDP
permit tcp any host x.x.x.x eq 3389
class-map type inspect match-all RDP
match access-group name ACL_RDP
policy-map type inspect ccp-policy-ccp-cls--1
  class type inspect RDP
    inspect
When I type the class type line, I get an error %No specific protocol defined in class RDP for inspections all protocols will be inspected.
Is there a better way to do the allowing of RDP through the firewall ?
Is the error I listed anything to worry about ?
Ron
Diego Armando C... Wed, 06/23/2010 - 07:28
  • Bronze, 100 points or more
That messasge is not a problem. But you can specify in your class map a protocol and a port. You could match protocol TCP and port 3389 instead of using the ACL. That way the message log will not appear. But  your current config must be working fine
