3500xl Switch - problem accessing Switch Rom
Jun 11th, 2010
I recenlty received some 3500XL switches and I am trying to reset their password so I can erase all configs.  I am starting by trying to follow the instructions to boot to the Switch Rom where I can reset the password.  My instructions have me:
- Hold mode button and connect power cable
- once the light above the 1x port goes off, release mode
I am suppose to see the "password-recovery mechanism is enabled" line but I only see "Xmodem file system is available" instead.  If i continue on in the instructions i get access denied when I try to access the flash dir (dir flash command).
Can someone help me with what I am doing wrong?
Max
truefit16066 Fri, 06/11/2010 - 11:26
I am already following these instructions as I posted in my original post.
This is a 3524 XL and I am releasing the mode button when the port 1x light goes out (as I specified in the original post).  Instead of it saying The password-recovery mechanism is enabled.
I am seeing the following:
C3500XL Boot Loader (C3500-HBOOT-M) Version 11.2(8.2)SA6, MAINTENANCE INTERIM SO
FTWARE
Compiled Wed 23-Jun-99 18:46 by boba
starting...
Base ethernet MAC Address: 00:30:94:c2:20:c0
Xmodem file system is available.
The system has been interrupted prior to initializing the
flash filesystem.  The following commands will initialize
the flash filesystem, and finish loading the operating
system software:
    flash_init
    load_helper
    boot
switch:
Therefore when I try to continue and get to the command "dir Flash" it gives me an access denied permission message.
Please help
Chetan Kumar Ress Fri, 06/11/2010 - 11:45
what about this command
switch: rename flash:config.text flash:config.old
or
switch: delete flash:config.text
Tell me the output of ALL of these commands---copy and paste exactly what it says!
Chetan Kumar
truefit16066 Fri, 06/11/2010 - 11:51
Thanks for the help:
As you can see from the output, it stated "rename" was an invalid argument.  But using the delete command it prompted me if I wanted to delete, but when I select 'y' I get invalid argument.  You will see that I tried "Y" and "Yes" as well.
FTWARE
starting...
Base ethernet MAC Address: 00:30:94:47:46:00
system software:
    flash_init
    load_helper
    boot
rename: invalid argument
Unknown cmd: switch:
Are you sure you want to delete "flash:config.text" (y/n)?n
File "flash:config.text" not deleted
switch:
FTWARE
starting...
system software:
    flash_init
    load_helper
    boot
Are you sure you want to delete "flash:config.text" (y/n)?y
File "flash:config.text" not deleted -- invalid argument
Unknown cmd:
switch: delete flash:config.txt
Are you sure you want to delete "flash:config.txt" (y/n)?Y
File "flash:config.txt" not deleted -- invalid argument
Are you sure you want to delete "flash:config.text" (y/n)?yes
switch:
truefit16066 Fri, 06/11/2010 - 12:14
Ok I found my problem, lucky for me there was another doc on the internet that point out the importance of including the ":" at the end of the command:  "dir flash:".
Not adding that was causing my problem.
Thanks for the assistance though.
