AP 1242AG passing DHCP requests
Jun 11th, 2010
I have 2 1242AG APs setup with one SSID and no vlans configured.  The APs are connected to a switch along with my DHCP server.  Clients are able to connect to the SSID but are unable to get an IP from the server.  Clients can plug into the switch and get an IP.  If I configure a static IP on the wireless card, the client works fine.
Is there something I'm missing on the AP to allow DHCP requests to pass through?  IPhelper?
Here is the AP info:
AIR-AP1242AG-A-K9
12.4(21a)JA1
Thanks.
John
Leo Laohoo Fri, 06/11/2010 - 15:02
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Yes you "have".  By default it's VLAN 1.
Right-o.  Is the link from the AP to switch configured as a dot1q Trunk?
jhbrubaker Fri, 06/11/2010 - 15:56
It is connected to a Cisco Small Business Pro ESW-540 switch.  All ports are configured for Trunk mode and dot1q from what I can see.
Leo Laohoo Fri, 06/11/2010 - 17:15
  • Hall of Fame,
    2017 LAN, Wireless
Can you post your config of both?
Elliott Shawd Wed, 06/16/2010 - 09:33
Are you able to reach the internet when you statically configure an ip?
jhbrubaker Wed, 06/16/2010 - 11:35
Yes.  With a static IP, WiFi users are perfectly fine.
I went through the port wizard on the switch state that APs are connected.  Waiting for staff at that location to test again.
smayanja123 Mon, 04/08/2013 - 13:58
If you did not configure any vlans then configure the ports to be access ports not Trunks.
#sw access
#sw access vlan 1
#no shut
That will do it
Sam
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
