Does anyone know of a product that alerts you to configuration changes?
Jun 11th, 2010
The product needs to be:
- Free
- for Non-standard Cisco products (Adtran routers)
- can be implemented on Windows or Linux (VMWare instance)
Thanks guys for your help. By the way, I looked at RANCID already. It was ok. Anything else??
Aaron Harrison Fri, 06/11/2010 - 13:55
  • Community Spotlight Award,
    Member's Choice, May 2015
If you are feeling a little low on cash, you can use the EEM feature (Embedded Event Manager) on some platforms to mail out a config whenever it's changed... here's one example, google EEM for others:
http://blog.howardtang.com/?p=8
Aaron
Please rate helpful posts...
saquib.tandel Fri, 06/11/2010 - 22:47
SolarWinds NCM does a great job for a fee...
checkout the trial version.
