Change passwords
Jun 11th, 2010
I want to change the telnet and enable passwords on my routers. Could someone post the commands up here? Thanks.
terrygwazdosky Fri, 06/11/2010 - 13:14
Enable password change: enable secret
For  the telnet password, it depends on how you have it setup.  Is it defined under the "line vty" section or are you using local aaa accounts to do authentication?
narendrakumar1987in Sat, 06/12/2010 - 00:09
Hi Sean,
            To set telnet password
R1#configure  terminal
R1(config)#username Sean password seanpass
R1(config)#line vty 0 4
R1(config-line)#login local
             To set an enable password
R1#conf t
R1(config)#enable password MypAssword
Do revert back for queries.
Hope it helps !!!
Happy Networking,
Narendrakumar B
Related Content
