1811 and COmcast DHCP trouble
Jun 11th, 2010
I have a router 1811 that was configure to use comcast static ip now is need to switched to DHCP.
I have started with a very simple config to try and establish an ip address on f1 or f0 but I can get the 1811 to pick one.
all I have done is:
int f1
ip add dhcp
no shut
if I go to ip int brief I have no IP address. If I do debug dhcp I get it can't get an IP or the IP is not for this device.
Any help would be greatly appreciated.
Reza Sharifi Fri, 06/11/2010 - 14:39
Hi Marley,
In the global config mode try this command:
"service dhcp"
and test again
If still no connection post the configs for your interfaces.
Marley Brown Sun, 06/13/2010 - 17:41
I will try this on Wednesday. I have limited access to Comcast service with DHCP. If you have any other suggestions please let me know and I will try all of it.
Here is my int config:
interface FastEthernet1
description $ETH-WAN$
ip address dhcp
ip virtual-reassembly
duplex auto
speed auto
I am just trying the basics until I can get an IP address.
Thank you,
zartar911 Fri, 06/11/2010 - 18:06
Hi Marley,
If you have an access-list attached to your interface for incoming traffic, make sure you allow bootpc.
"permit udp any eq bootpc any eq bootpc"
