Cisco Provided OS Patches for UCCX 7.0
Answered Question
Jun 11th, 2010
I am getting ready to install UCCX 7.0 and patch it up (OS Disks are 2003.1.5) but for the life of me I can't find any OS patches under this area of the downloads section.  I can find a lot of UCCX patches but nothing on the OS.  Knowing that UCCM (CallManager) was windows based up until release 4.3 I went over there and found OS patches there.  My question is this:  Is there any functional difference between the MCS patches for UCCM 4.3 and any that might be elsewhere for UCCX?  I would prefer to stay with the correct MCS OS patch if there is one but honestly it makes sense that it wouldn't be.
Opinions?
Correct Answer by Aaron Harrison about 6 years 7 months ago
Hi Dennis
Those are the correct patches; so there's no difference.
Well done spotting them.
Aaron
Please rate helpful posts...
Overall Rating: 4 (5 ratings)
Correct Answer
Aaron Harrison Fri, 06/11/2010 - 16:51
Hi Dennis
Aaron
Walter Solano Fri, 06/11/2010 - 18:12
5 point for You Aaron, this is completely correct the patches for the OS are the same. I dont know why they are under the CUCM and not under UCCX.
Please rate this post if was helpful
Walter Solano
Cisco UCCX Specialist
