How 1524 Mesh APs connect to indoor APs 1140...
Jun 12th, 2010
I have to connect Mesh Access Point 1524 to Indoor Access Point 1140 for Internet connectivity with in building.
In attached diagram , Building A is the Main office where we are planning to use 1) Mesh AP 1524 (Root) , Router 2811, POE Switch, ASA 5500, WLAN controller , Indoor AP 1140.
In other buildings B,C,D,E,F We are planning to use Mesh APs 1524 (MAP) and Indoor APs 1140.
So anybody can help me that
1) How this 1524 Mesh Access point is connected to Indoor Access point 1140 in building B,C,D,E,F (As shown in diagram).
Thanks in advance
Rajendra
Overall Rating: 2 (1 ratings)
Leo Laohoo Sat, 06/12/2010 - 04:08
Are you trying to bridge both buildings using Wireless?  If yes, are both building in line-of-sight and no tall structures in between?  If yes, then you should be configured point-to-point wireless bridge.
Raju_Talele_2 Sun, 06/13/2010 - 23:58
Hello Leolaohoo,
Thanks for Reply.
I have to connect building A to Building B,C,D,E,F by wireless.  There is clear line of sight between building A and all other buildings. Maxi distance between building A and other buildings is less than 700 mtrs. I have to create Mesh network so that users can use internet outside the building .(as shown circle in the diagram) as well as inside the buildings. So I consider Root Mesh RAP 1524 at building A and Mesh AP MAP 1524 at other buildings. Point to Multipoint connectivity.
So root AP is at the building A and MESH AP at other buildings and AP 1140 will be used inside the buildings.  So pl guide me,  How 1524 connect to 1140 in building B,C,D,E,F to get internet connectvity within the buildings.
Rajendra
Leo Laohoo Mon, 06/14/2010 - 15:55
Wireless Bridges Point-to-Point Link Configuration Example
http://www.cisco.com/en/US/customer/tech/tk722/tk809/technologies_configuration_example09186a008058f53e.shtml
Troubleshoot Common Problems with Wireless Bridged Networks
http://www.cisco.com/en/US/customer/tech/tk722/tk809/technologies_tech_note09186a0080094c6e.shtml
Hope this helps.  Please don't forget to rate useful posts.  Thanks.
Raju_Talele_2 Mon, 06/14/2010 - 22:01
Sorry, I do not get access to this page . following error occurred while accessing.
"Forbidden File or Application "
