Cisco Unified Communications Manager required
Answered Question
Jun 12th, 2010
Is it absolutely necessary to install the Cisco Unified Communications Manager to use/setup the Cisco Unified Wireless IP Phone 7921G ?
Or can I just connect the phone to the Internet and get incoming SIP calls directly from the VoIP provider?
Pit
Correct Answer by Aaron Harrison about 7 years 2 weeks ago
That would be a question for the supplier that you purchased it from...
Otherwise there is a healthy market for anything with a Cisco badge on ebay, and lots of specialists dealing in used kit all over the world.
Aaron
The 7921 only supports SCCP which is Cisco's proprietary signalling protocol. Same applies for all the Cisco 792x wireless models as far as I'm aware.
So no, you can't connect it to a SIP provider. There are probably other manufacturers out there doing SIP wireless handsets that would be more appropriate, and likely cheaper.
Aaron
Please rate helpful posts and mark answered questions that you've got a satisfactory response from to help identify useful content in the forums...
https://supportforums.cisco.com/docs/DOC-6212
Overall Rating: 5 (2 ratings)
Correct Answer
Aaron Harrison Sat, 06/12/2010 - 05:24
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
Pit Fritz Sat, 06/12/2010 - 12:44
Thanks for your prompt and helpful answer.
Unfortunately I just bought a 7921G which is now of no use for me.
Is there a possibility to give it back?
Correct Answer
Aaron Harrison Sun, 06/13/2010 - 03:10
Aaron
