Error in Cisco 2960 Switch
Jun 12th, 2010
When I start the switch, I have error !!!WARNING
: The Switch is not usable.
And also,
POST: PortASIC CAM Subsystem Tests: Begin
TCAM (asic:0, bit:55) data bus test failed
Post CAM test failed
unable to create l2trace server process, socket_open() failed
Hope any one can help me to fix it.
Giuseppe Larosa Sat, 06/12/2010 - 02:40
  • Hall of Fame,
    Founding Member
Hello Dasuntha,
this is an hardware failure of TCAM data bus you need to replace the switch being a fixed configuration switch
if you have a valid service contract you can open an RMA to have the switch replaced.
Hope to help
Giuseppe
Dasuntha Dinesh Sat, 06/12/2010 - 03:05
Thanks for your reply.
Trying my best to fix it...
Do you think If i try to load the IOS again to the switch & it'll fix the problem...
Giuseppe Larosa Sat, 06/12/2010 - 03:40
  • Hall of Fame,
    Founding Member
Hello Dasuntha,
no, it is an hardware problem not a question of IOS image version
Hope to help
Giuseppe
