7609-S Xmodem
Jun 12th, 2010
hi, everyone.
i have a question....
i tried to load IOS image to 7609-S but i couldn';t.....
so can you check my xmodem  log under?
I don't know why i can't load from xmodem.
rommon 4 > confreg
           Configuration Summary
   (Virtual Configuration Register: 0x3921)
enabled are:
[ 0 ] load rom after netboot fails
[ 1 ] console baud: 115200
boot: ...... the boot helper image
do you wish to change the configuration? y/n  [n]:  y
enable  "diagnostic mode"? y/n  [n]:  n
enable  "use net in IP bcast address"? y/n  [n]:  n
disable "load rom after netboot fails"? y/n  [n]:  n
enable  "use all zero broadcast"? y/n  [n]:  n
enable  "break/abort has effect"? y/n  [n]:  n
enable  "ignore system config info"? y/n  [n]:  n
change console baud rate? y/n  [n]:  y
0=9600, 1=4800, 2=1200, 3=2400, 4=19200, 5=38400, 6=57600, 7=115200
enter rate  [7]:
change the boot characteristics? y/n  [n]:  y
enter to boot:
0 = ROM Monitor
1 = the boot helper image
2-15 = boot system
[1]:  2
   (Virtual Configuration Register: 0x3922)
enabled are:
boot: ...... image specified by the boot system commands or default to: cisco2-
C7600-RSP720/SP
do you wish to change the configuration? y/n  [n]:  n
You must reset or power cycle for new config to take effect
rommon 5 > reset
Resetting .......
System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
C7600-RSP720/SP platform with 1048576 Kbytes of main memory
Autoboot executing command: "boot "
Initializing ATA monitor library...
boot: cannot determine first file name on device "bootdisk:"
rommon 1 >
rommon 1 >
rommon 1 > xmodem c7600rsp72043-adventerprisek9-mz.122-33.SRE1.bin
Do not start sending the image yet...
Invoke this application for disaster recovery.
Do you wish to continue? (y/n)  [n]:  y
At Line: 741
At Line: 744
At Line: 286
At Line: 741
At Line: 744
At Line: 380
At Line: 413
At Line: 523
At Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 523
At Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 523
At Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 523
At Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 523
At Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 523
At Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 523
At Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 523
At Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 523
At Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 523
At Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 659
At Line: 741
At Line: 744
At Line: 670
BB0BB0At Line: 415
At Line: 472
At Line: 384
At Line: 741
At Line: 744
At Line: 289
At Line: 291
At Line: 331
At Line: 741
At Line: 744
Timeout waiting for data - aborting download...
rommon 2 > xmodem -c c7600rsp72043-adventerprisek9-mz.122-33.SRE1.bin
At Line: 741
At Line: 744
At Line: 286
At Line: 741
At Line: 744
At Line: 380
At Line: 413
At Line: 523
At Line: 525
CAt Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 523
At Line: 525
CAt Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 523
At Line: 525
CAt Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 523
At Line: 525
CAt Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 523
At Line: 525
CAt Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 523
At Line: 525
CAt Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 523
At Line: 525
CAt Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 523
At Line: 525
CAt Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 523
At Line: 525
CAt Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 523
At Line: 525
CAt Line: 536
At Line: 648
At Line: 741
At Line: 744
At Line: 659
At Line: 741
At Line: 744
At Line: 670
BB0BB0At Line: 415
At Line: 472
At Line: 384
At Line: 741
At Line: 744
At Line: 289
At Line: 291
At Line: 331
At Line: 741
At Line: 744
rommon 3 >
rommon 3 > xmodem -cs115200 c7600rsp72043-adventerprisek9-mz.122-33.SRE1.bin
Note, if the console port is attached to a modem, both the
console port and the modem must be operating at the same baud
rate. Use console speed 115200 bps for download [confirm](y/n)   [n]:  y
Download will be performed at 115200. Make sure your terminal
emulator is set to this speed before sending file.
Ready to receive file ...
At Line: 741
At Line: 744딇
rommon 23 > set
PS1=rommon ! >
RELOAD_TYPE=1
BSI=0
NT_K=0:0:0:0
RET_2_RCALTS=
LOG_PREFIX_VERSION=1
BOOT=bootflash:
RANDOM_NUM=363196791
PF_REDUN_CRASH_COUNT=0
?=0
rommon 24 > confreg
enabled are:
boot: ...... image specified by the boot system commands or default to: cisco2-C7600-RSP720/SP
rommon 25 > confreg
monitor: command "confreg" not found
rommon 26 > confreg
enabled are:
enter rate  [7]:
enter to boot:
0 = ROM Monitor
2-15 = boot system
[2]:  2
enabled are:
rommon 27 >
edsge teenstra Thu, 10/28/2010 - 01:36
Hi Kahn
I have a RSP720-3CXL-10GE new from box, upgraded from the autobahn76 software to a SRE1 software by our customer now it crashes after the MSFC4 being taking over the booting process from the SP supervisor , i tried everything to get it working again but it just will not boot, i have even resetted the ROMMON variables and cleared both sides the nvram.....
Now my last hope is to get XMODEM transferring the image and then booting it .... but i cannot get XMODEM working while i used it for recovery over 100 times ..
So my question is did you get XMODEM/YMODEM working  ?
THX
