06-12-2010 12:08 PM - edited 03-04-2019 08:45 AM
To Group
i have public pool IP of 252 i m running internet over it Media box is situated at inside LAN .my client want port forwarding
to access Media BOX and its lan ip is 192.168.10.30 i did following configuration but couldn't get success
correct me if i m wrong i think due to unavailability of public IP it wouldnt easy for me to do successful port forwarding
interface FastEthernet0/0
ip address 192.168.30.1 255.255.255.0
ip nat inside
interface FastEthernet0/1
ip address 210.2.144.150 255.255.255.248
ip nat outside
ip nat pool Forwarding 192.168.30.10 192.168.30.10 netmask 255.255.255.0 type rotary
ip nat inside source list 101 interface FastEthernet0/1 overload
ip nat inside destination list WOW pool Forwarding
access-list 101 permit ip 192.168.30.0 0.0.0.255 any
ip access-list extended WOW
permit tcp any any range 19 19000
2nd configuration i made on assumption that my client have public ip of 210.2.144.151
ip nat pool Forwarding 210.2.144.151 210.2.144.151 255.255.255.252
permit tcp 192.168.30.0 0.0.0.0 range 19 19000 any
ip nat inside source list WOW pool Forwarding
Corect me if i m wrong any where
Thanks /Regards
Solved! Go to Solution.
06-13-2010 03:52 AM
If I understand this correctly you have a range of public IP addresses and want your Media BOX to be available via Internet on the IP address 210.2.144.151. In order to do this you need one line of NAT configuration to NAT between 192.168.10.30 and 210.2.144.151.
For all other internal hosts you want to use NAT overload for outbound sessions and use the public IP address 210.2.144.150
ip nat inside
ip nat outside
ip nat inside source static 192.168.10.30 210.2.144.151
Since your topic is Port Forwarding I will give you an example on how this can be done. Let’s say that your MediaBOX has a web gui on TCP port 80 and you want to be able to access this via Internet. To use port forwarding or PAT (Port Address Translation) as we call it you can use the following configuration.
ip nat inside
ip nat outside
ip nat inside source static tcp 192.168.10.30 80 interface FastEthernet0/1 80
With this configuration you will have access to tcp port 80 on your MediaBOX when via 210.2.144.150 tcp port 80. You can add more than one line for each host.
/André
06-14-2010 12:46 AM
I had tested this configuration and worked fine, See if it works for you...
ip nat pool POOL1 192.168.30.10 192.168.30.10 netmask 255.255.255.0 type rotary
ip nat inside destination list 101 pool POOL1
access-list 101 permit tcp any any range 19 19000
Hitesh Vinzoda
Pls rate useful posts.
06-15-2010 08:28 AM
The first of the two configurations I provided is doing NAT between the two IP addresses 192.168.10.30 and 210.2.144.151 so all ports will be forwarded.
If you are coming from Internet and try to connect to 210.2.144.15 your sessions will end up at 192.168.10.30 regardless of the ports that are used.
/André
06-13-2010 03:52 AM
ip nat inside
ip nat outside
ip nat inside
ip nat outside
/André
06-13-2010 10:39 PM
Thanks for your reply but i need range of port for Media Bo from 19 to around 19000
waiting for your prompt response
06-15-2010 08:28 AM
/André
06-14-2010 12:46 AM
Hitesh Vinzoda
