Problem pinging internal host from WAN
Answered Question
I have a single host at a site I cannot ping through our WAN interface on the router, yet I can ping any other host on the LAN remotely. This host is reachable and can be pinged locally at the site. When I do a traceroute from the main site, the ping stops at the serial interface of the router. When I check the router for a route to this host, a route exists.
I'm wondering what could be preventing me from communicating with this specific host remotely.
I don't know if this helps but we have several sites set up the same way, and with 3 of the sites we have this problem. The sites that are working have Cisco 2600 series routers. The sites that aren't working have Cisco 1800 series routers. The remote host that we cannot reach is configured statically with 192.168.x.254.
Some assistance troubleshooting would be helpful.
Correct Answer by Reza Sharifi about 6 years 7 months ago
John,
If it has multiple interface and there are multiple subnets involved in your network, then the Linksys must have some sort of static route for your other locations to be able to reach it.
Also, if you have diagram you can post maybe I can help you better.
Reza
Overall Rating: 5 (1 ratings)
Reza Sharifi Sat, 06/12/2010 - 15:32
Does the host you can not ping has a default gateway?
Is the host you can not ping located in the same subnet as the once you can ping?
Reza
Reza Sharifi Sat, 06/12/2010 - 15:59
Hi John,
Ok, so does this Linksys router have a default route or default gateway?
Reza
Correct Answer
Reza Sharifi Sat, 06/12/2010 - 16:22
John,
Reza
From the Corporate MPLS network, I can ping the serial interface (172.16.0.54) and any 192.168.208.x host within the LAN except 192.168.208.254.
From within the LAN I can ping 192.168.208.254 from the Cisco 1800 router and from any other host on 192.168.208.x.
I'm not sure why I can't get past the serial interface to 192.168.208.254.
John
Reza Sharifi Sat, 06/12/2010 - 19:35
John,
On the Linksys you need a default route toward the outside (Internet) and specific static route towards the inside 172.16.0.0 subnet
I think the reason you can't reach 192.168.208.254 is because the Linksys doe not have route back to the 172.16.0.0 subnet
Reza
Related Content
