ASA RegEx Match
Jun 12th, 2010
Hi All,
I've configured a FTP inspect policy-map, within the policy map I'm using the match filename command to identify certain files
regex test ^cisco.*
policy-map type inspect ftp FTP_PMAP
match filename regex test
   reset
The problem I have is that the regex above does not work but the regex below does.
regex test2 cisco.*
filenames are in the format cisco1.txt, cisco2.txt etc....
Any ideas?  the ASA is running version 8.2(2)
Marcin Latosiewicz Sun, 06/13/2010 - 02:11
  • Cisco Employee,
Peter,
Did a short test.
^cisco.* should match anything begining with "cisco" followed by any number of characters.
ciscoasa# test regex cisco2.txt ^cisco.*
INFO: Regular expression match succeeded.
ciscoasa# test regex 1_cisco2.txt ^cisco.*
INFO: Regular expression match failed.
If you want to match the ciscoX.txt files
ciscoasa# test regex cisco2.txt cisco[0-9]\.txt
Theory is regexps in test and in policy maps should be working same way ... provided no extra characters are added.
