2924 port security sticky
Jun 12th, 2010
ok im trying to set my FastEth port 3 into sticky security, but when i go to enter commands this is what i get:
BasementSwitch>en
Password:
BasementSwitch#config t
Enter configuration commands, one per line.  End with CNTL/Z.
BasementSwitch(config)#int fa0/3
BasementSwitch(config-if)#switchport access?
  access    Set access mode characteristics of the interface
  mode      Set trunking mode of the interface
  multi     Set characteristics when in multi-VLAN mode
  priority  Set 802.1p priorities
  trunk     Set trunking characteristics of the interface
  voice     Voice appliance attributes
BasementSwitch(config-if)#switchport access vlan 1
BasementSwitch(config-if)#switchport port-security ?
% Unrecognized command
can someone help me with this, thanks.
Reza Sharifi Sat, 06/12/2010 - 18:15
This is what you should see after ?
Management-Switch(config-if)#switchport port-security ?
  aging        Port-security aging commands
  mac-address  Secure mac address
  maximum      Max secure addresses
  violation    Security violation mode
maybe port securiy in not supported
nate faulds Sat, 06/12/2010 - 18:18
yea w
hen i boot it says i downloaded the LRE image, im downloading the non  LRE and hopefully that will help
nate faulds Sat, 06/12/2010 - 18:50
yea i just nopticed at boot it says that my 2924XL isnt LRE compatable, so i am re uploading a non LRE
