06-13-2010 06:56 AM - edited 03-06-2019 11:33 AM
Hi every body.
I have few questions.
My book says , a vtp transparent switch stores vtp info in vlan.dat and in running-config . This vtp con can be saved from running-config to startup-config by using copy running-config startup-config. If the switch relaods and finds the contents of vlan.dat are different from startup-config, switch uses vlan.dat contents.
How can the contents of vlan.dat be different from startup-config?
for example
Sw(config) vtp domain cisco
Switch# copy running-config startup-config.
Now both vlan.dat and startup-config has same vtp info i.e vtp domain cisco
Now i change the domain name to test.
switch(config) vtp domain test ( at this point, will switch not update its vlan.dat with new domain name test? )
switch# copy running-config-startup-config
If switch has updated its vlan.dat with new domain name "test", the contents of both vlan.dat and startup-config should be same.
Thanks and have a good day.
06-14-2010 12:15 AM
Hi every body.
for example
Hi Sarah,
The vlan and VTP information is actually kept in the VLAN.DAT file in Flash memory, and the contents of Flash are kept on a reload. The file has to be deleted manually in order to remove the vlan and vtp information from the switches.
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00800c4546.shtml
Hope to Help !!
Ganesh.H
