Cannot ping Integrated service engine from the local network
Jun 13th, 2010
ip source-route
ip cef
ip dhcp excluded-address 192.168.0.129 192.168.0.135
ip dhcp pool Phone
   network 192.168.0.128 255.255.255.128
   default-router 192.168.0.130
   option 150 ip 192.168.0.130
no ipv6 cef
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class cause-code 1
no-circuit
voice register global
mode cme
interface Loopback0
ip address 10.1.10.2 255.255.255.252
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.3
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.0.3 255.255.255.128
ip helper-address 192.168.0.10
interface Vlan20
ip address 192.168.0.130 255.255.255.128
ip helper-address 192.168.0.3
interface Vlan100
no ip address
ip forward-protocol nd
ip http server
ip http authentication aaa
ip http secure-server
ip http path flash:
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
Aaron Harrison Sun, 06/13/2010 - 11:23
You have 'service-module ip default-gateway 10.1.10.3' on the interface - the default gateway for the service engine would be the router's interface, so this should be :
service-module ip default-gateway 10.1.10.1
You would need to restart the CUE module for this to take effect.
Aaron
aneeshajay Sun, 06/13/2010 - 11:30
I did change the ip and still cannot ping it. Does it have anything to do with the 2960 switch which i am using?
Aaron Harrison Sun, 06/13/2010 - 14:09
OK - step by step:
1) Can you ping the CUE from the router itself?
2) If you are on the LAN (i.e. in the 192.168.0.x range) you will either need your default GW to be this router, or the device that is currently your default gateway will need to have a route for the 10.1.10.x network pointed to this router.
Aaron
