WAE inline integration & CMS communication ports
Jun 13th, 2010
Hi all,
i need to deploy WAE with inline card towards two routers. as i understand, i need to use each group ports (lan 0 & wan 0, lan 1 & wan 1) to each router.
i am using the wae as a vlan mapping, ingress vlan 700 egress vlan 701 (interface vlan on routers is 701). is there any deployment limitation i should know about ?
another question is that the CMS is sitting behind a FW. each remote WAE is using OOB Management. which ports should i open at the FW ?, is it only 443 ?
thanks,
Zach Seils Wed, 06/16/2010 - 06:35
  • Cisco Employee,
Avi,
All of the communication between the WAAS devices and the Central Manager uses tcp/443.  Note that connections can be initiated from either direction, so your firewall rules should account for that.
Zach
