Remove VLAN from my list
Answered Question
Jun 13th, 2010
Good evening every body;
I create a new vlan with my packet tracer 5.1; and then i put on it 2hosts
then i remove the hosts to vlan 1 so the new vlan 34 is empty==> i want to remove this vlan from my switch list
Please check the picture below
Correct Answer by Reza Sharifi about 6 years 8 months ago
Hi Samy,
Not familiar with packet tracer but if you have access to the switch via cli, just login and issue these commands:
config t
no vlan 34
Reza
Overall Rating: 5 (2 ratings)
Correct Answer
Reza Sharifi Sun, 06/13/2010 - 17:24
Hi Samy,
config t
no vlan 34
Reza
samychihi21 Sun, 06/13/2010 - 18:35
Thank youuuu very much Reza
you are very helpful.
it is working :-)
Thank you again :-)
