T.37 Offramp - Confirmation receipts
Answered Question
Jun 13th, 2010
Hi, is it possible to get a delivery reciept/confirmation for an outgoing fax transmission using T.37 Off_Ramp?
Thanks in adavance
Brendan
Correct Answer by Jonathan Schulenberg about 6 years 8 months ago
That depends on your definition of confirmation receipt. You CAN receive an SMTP-based Message Delivery Notification; however, you cannot provide a receipt to the sending device directly. This is a limitation of T.37 because it acts an asynchronous relay. The onramp T.37 gateway provides confirmation to the sending device that it has received the fax (over T.30) and then closes communications with the sending device. The only opportunity for a receipt is at the off-ramp gateway but this is not communicating with the original sender directly.
http://www.cisco.com/en/US/docs/ios/voice/fax/configuration/guide/vf_t37_str-fwd_fax_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1076149
You may want to investigate T.38 as a reliable synchronous relay of fax data if you need the actual sending device to get a traditional confirmation or failure notification.
Overall Rating: 5 (1 ratings)
Correct Answer
Jonathan Schulenberg Tue, 06/15/2010 - 03:43
Brendan Marmont Wed, 06/30/2010 - 19:17
Thanks Jonathan, we have the mdn line in our config, however I only get a dsn failure receipt to the Outlook client, I need sucessfull receipts also. Is there soemthing I am missing from our config below? Do you have a good doc for setting up T.38 by chance?
Cheers again
Brendan
fax receive called-subscriber $d$
fax send transmitting-subscriber $s$
fax interface-type fax-mail
mta send server 10.10.0.16 port 25
mta send subject "Incoming Fax - AKL"
mta send mail-from username $s$
mta receive aliases fax.domain.com
mta receive maximum-recipients 10
mta receive generate mdn
mta receive generate permanent-error
dial-peer voice 60001 mmoip
description Inbound peer for T.37 off-ramp operation
service fax_offramp
information-type fax
incoming called-number .
image resolution standard
mdn
dsn delayed
dsn success
dsn failure
sergesandler Mon, 07/12/2010 - 04:58
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You have to request a delivery receipt when composing a message from your mail client. Then on successful fax transmission, ‘Fax Daemon’ will send a Delivery Status Notification with the text like
Delivery was successful to the following recipient(s):
Successful with the status of: 250 2.5.0 Requested mail action ok, completed.
By the way, T.37 can be used in synchronous way, without intermediate MTA. In this case success DSNs are not needed, please see http://www.sandlerco.com/t37fsp4cisco.htm for details.
dgriencisco Tue, 11/30/2010 - 16:11
Cisco crashes when i tried with return-receipt from Apple Mail ('Disposition-No
tification-To) turned on. Can you tell me what could be the problem?
