How to configure spa9000, SPA400 and spa8800 to build VOIP solution?
Jun 13th, 2010
I am experimenting with VOIP with following goal:
Build cost effective and reliable VOIP solution for a company with two  branch offices (US and UK) with about 10 staffs each office.
Other general requirement
1. For each sites 4 local PSTN lines are available to connect to the VOIP system
2. Each sites need about 12 extensions (8 VOIP/SIP phone and 4 analog phones as extensions)
3. Provide voice mail functionality for all extensions.
4. Site 1 extension starts with 100 and site 2 extensions starts with 200
5. Users from either site should be able to dial local numbers from either locations using the PSTN lines
     Eg. dialed numbers starting with 9 should dial out through one of 4 PSTN lines connected to US office system
           dialed numbers starting with 8 should dial out through one of 4 PSTN lines connected to UK office system
6. Allow to connect to third party VOIP carrier to call any other countries (eg. numbers starting with 7 indicating to use the VOIP carrier to dial out)
Please suggest how can I build solution for this.
Can we use:
1. Cisco SPA9000  as central IP PBX in data center located in US.
2. Cisco SPA400 in each site as PSTN termination - 4 lines; which supports 16 voice mails
2. Cisco SPA8800 in each site as telephony gateway to provide 4 analog extension lines
Alberto Montilla Mon, 06/21/2010 - 02:52
  • Cisco Employee,
Dear Sir;
SPA9000 Voice System is not designed/supported for multisite deployments like the one you mention. I suggest you take a look at the UC500 solution. UC520 should give you a solution to accomplish the below described scenario.
Alberto
Related Content
