Disable port security
Answered Question
Jun 13th, 2010
Good morning every body :-)
i need your help;
i activated the port security in my packet tracer, and now this is what i have:
Switch#show port-security int fast 0/3
Port Security              : Enabled
Port Status                : Secure-up
Violation Mode             : Shutdown
Aging Time                 : 0 mins
Aging Type                 : Absolute
SecureStatic Address Aging : Disabled
Maximum MAC Addresses      : 1
Total MAC Addresses        : 1
Configured MAC Addresses   : 1
Sticky MAC Addresses       : 0
Last Source Address:Vlan   : 00D0.D3D1.3B86:1
Security Violation Count   : 0
actually i have 2 problems
1-i want desable port security
2-Sticky mac addresses is working fine after configuration, but it show always 0 except if i change Maximum MAC Addresses; is-it normal, or i made a mistake.
thank you very much for your help.
i'm new in cisco switching so i appreciate so much your help :-)
Regards.
Correct Answer by Ganesh Hariharan about 7 years 2 weeks ago
Hello every body, thanks for your help :-)
As you can see bellow
Aging Time                 : 0 mins
Configured MAC Addresses   : 0
Sticky MAC Addresses       : 1
after that i checked if i can remove the security-port and it is not working for port-security sticky
*Please see below and advice
Switch#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Switch(config)#int fast 0/3
Switch(config-if)#no switchport port-security maximum
Switch(config-if)#no switchport port-security mac-address sticky
Switch(config-if)#^Z
%SYS-5-CONFIG_I: Configured from console by console
Switch#
Switch#
Switch#
Port Security              : Disabled
Port Status                : Secure-down
Aging Time                 : 0 mins
Maximum MAC Addresses      : 1   => should be 0
Total MAC Addresses        : 0
Sticky MAC Addresses       : 1    =>should be 0
Switch#
Thanks in advance
Hi Samy,
If you disable sticky learning by using the no switchport port-security mac-address sticky interface configuration command or the running configuration is removed, the sticky secure MAC addresses remain part of the running configuration but are removed from the address table. The addresses that were removed can be dynamically reconfigured and added to the address table as dynamic addresses.Without the sticky option, the mac-address association goes away after a specified period of time.
When you configure sticky secure MAC addresses by using the switchport port-security mac-address sticky mac-address interface configuration command, these addresses are added to the address table and the running configuration. If port security is disabled, the sticky secure MAC addresses remain in the running configuration.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_37_se/command/reference/cli3.html#wp1948361
Hope to Help !!
Ganesh.H
Correct Answer by Hitesh Vinzoda about 7 years 2 weeks ago
You can disable the port-security as suggested by Reza or Ganesh, The answer related to your 2nd question is as below
Aging Time                 : 0 mins
Configured MAC Addresses   : 1                         >> This should be "0"
Sticky MAC Addresses       : 0                              >> This should be "1"
As you haven't configured the mac address it should be 0
also the mac address learned is via sticky so it should be 1
If you have configured sticky and port security is enabled than you are good to go. I think its problem with the packet tracert SIM.
i need your help;
Aging Time                 : 0 mins
Regards.
To disable port security on an interface, use the no form of this command.
http://www.cisco.com/en/US/docs/ios/security/command/reference/sec_s6.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Correct Answer by Reza Sharifi about 7 years 2 weeks ago
Hi Samy,
If you want to delete port security just login via cli and under that specific port do the following:
Reza
Overall Rating: 5 (4 ratings)
Correct Answer
Reza Sharifi Sun, 06/13/2010 - 20:34
  • Cisco Designated VIP,
    2017 LAN
Hi Samy,
Reza
Correct Answer
Ganesh Hariharan Mon, 06/14/2010 - 02:10
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
i need your help;
Aging Time                 : 0 mins
Regards.
Hope to Help !!
Ganesh.H
Correct Answer
Hitesh Vinzoda Mon, 06/14/2010 - 03:07
  • Silver, 250 points or more
Aging Time                 : 0 mins
samychihi21 Mon, 06/14/2010 - 12:00
Thank you very much for your help,
i will check that to nif=ght at  home
@ Ganesh from TATA
happy to see your message, i always reply to your messages from Telecom italia sparkle :-)
samychihi21 Tue, 06/15/2010 - 09:29
Aging Time                 : 0 mins
Switch#conf t
Switch#
Switch#
Switch#
Aging Time                 : 0 mins
Switch#
Thanks in advance
Correct Answer
Ganesh Hariharan Wed, 06/16/2010 - 08:05
Aging Time                 : 0 mins
Switch#conf t
Switch#
Switch#
Switch#
Aging Time                 : 0 mins
Switch#
Thanks in advance
Hi Samy,
Hope to Help !!
Ganesh.H
samychihi21 Wed, 06/16/2010 - 20:16
Dear Ganesh;
Thank you very much for your answer.
You are really helpful :-)
