test DNSSEC
Jun 14th, 2010
In july 2010, the servers DNS will be modify.
http://www.root-dnssec.org/
https://www.dns-oarc.net/oarc/services/replysizetest
On my LAN (PC win XP SP3 with firewall down and anti-virus down too), i tested this command:
nslookup -q=txt rs.dns-oarc.net
The answer is:
rst.x4001.rs.dns-oarc.net.
rst.x3985.x4001.rs.dns-oarc.net.
rst.x4023.x3985.x4001.rs.dns-oarc.net.
"192.168.1.1 sent EDNS buffer size 4096"
"192.168.1.1 DNS reply size limit is at least 3823 bytes"
How to know if my firewall on my cisco 851 is the cause. Normally, it must be upper to 4000 bytes and no 3823 bytes.
Yhank you for your answers.
Panos Kampanakis Mon, 06/14/2010 - 14:41
  • Cisco Employee,
I would check if I am inspecting dns on your 851.
I hope it helps.
PK
stephane.roque Sun, 06/20/2010 - 03:43
I found the answer.
My cisco is ok for the dnssec.
The answer is:
The DNS reply show an answer with 3823 bytes. It's the config DNS server for reply.
