Cisco LMS3.2 Netconfig
k.desrosiers
I just started a new job and I am now in charge of the exploitation and surveillance of many different customer networks.
Most of these networks are managed with Cisco LMS (v3.2) which I'm not very familiar with.
I managed to create user-defined jobs so I could deploy different basic functionnalities over hundred of devices. Cool....
Nevertheless, I am now stuck with a job I can't figure out how to do...
I actually have to add ip sla command lines to around 150 devices (C1812) for a new customer.
The problem is that the 3rd and last octets of the ip adresses in there change: 3rd octet can be 2,3,12 and 13 and last octet would go from 10 to 254. accordind to the router (vlan id).
I found that Parameterized Templates might help me but I don't know how to proceed with that.
Any idea or tips from someone who have already used this?
Thanks in advance!
KatyD
ip sla  11
udp-jitter  172.27.3.43 16245 source-ip 172.27.13.43
frequency 300
tos 0
exit
ip sla  schedule 11 start-time now life forever
ip sla  12
udp-jitter  172.27.2.43  16245 source-ip 172.27.12.43
frequency 300
tos 0
exit
ip sla  schedule 12 start-time now life forever
Joe Clarke
Yes you have to use parameterized templates.  Your templates will look like:
ip sla  11
udp-jitter  $dest1 16245 source-ip $source1
frequency 300
tos 0
exit
ip sla  12
udp-jitter  $dest2 16245 source-ip $source2
frequency 300
tos 0
exit
Then, you will need to create parameter XML files according to http://SERVER/help/rme/fundamentals/netcfg_ParametTemplates.html#wp1380442 .
For example:
   172.27.3.43
  172.27.13.43
Thanks a lot for your answer!
Your examples help me see how I can to use these parameterized templates.
