IPCC Express Enhanced - Integration with 3rd Party Call Control
Answered Question
Jun 14th, 2010
Hi All... i'm looking at a solution at the moment where we need to employ IPCCx for the contact center features but not CUCM... Does anyone have any knowledge/experience connecting non Cisco call control with Cisco IPCCx across say a SIP trunk? Is this sort of thing done/possible?
Cheers,
Rich...
Correct Answer by Aaron Harrison about 7 years 1 month ago
Ah yes... forgot CME :-)
The other point is that the Agents need to be on IP handsets controllable via CTI, so they couldn't be lines on the PBX over the SIP trunk.
Aaron
UCCX uses the CCM JTAPI system to control phones, CTI Route points, CTI Ports etc, and uses CCM for authentication of users and lots of other stuff.
The bottom line is that it's very tightly integrated to CCM, and requires CCM to operate. You can't use it with other systems...
Aaron
Please rate helpful posts...
Overall Rating: 4.3 (3 ratings)
Correct Answer
Aaron Harrison Mon, 06/14/2010 - 04:50
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
Jonathan Schulenberg Mon, 06/14/2010 - 04:50
  • Cisco Designated VIP,
    2017 IP Telephony
Not supported. You will need to integrate it with UCM or CME. Either of those call agents can support a SIP trunk to a third-party PBX however.
Correct Answer
Aaron Harrison Mon, 06/14/2010 - 04:56
Aaron
ritsonr Mon, 06/14/2010 - 06:04
Nice one guys, thanks... We're seeing a lot of customers wanting the simplicity of a cloud based IPT solution to replace end of support Call Manager 4.2 implementations but they still want the functionality of IPCC and many of the cloud based options dont offer many features compared... So we'll go with decommission of server based CUCM and replace with CME... thanks again
